[GRASS-dev] Re: Wingrass-Installer + Win7
Helmut Kudrnovsky hellik at web.de
Mon Dec 21 14:04:32 EST 2009
>-----Ursprüngliche Nachricht-----
>Von: "Massimo Di Stefano" <massimodisasha at gmail.com>
>Betreff: Re: [GRASS-dev] Re: Wingrass-Installer + Win7
hi Massimo
>i had not to much time to test it, but if you point me to a script to beused as "unit test" maybe based on spearfish, i'll be appy to try it.
>let me know if you need to test a precise instruction.
>regards,
>Massimo.
there is some kind of "unit test":
http://trac.osgeo.org/grass/wiki/HowToTestGrass6
and
http://trac.osgeo.org/grass/wiki/HowToTestGrass6#SeeAlso
with tests for raster, vector, interpolation and image processing
best regards
Helmut
Il giorno 21/dic/2009, alle ore 13.18, Hamish ha scritto:
>>> Modified: grass-web/trunk/grass64/binary/mswindows/index.html
>>> +<li><I> For Windows XP and Vista, 32 and 64 bit</I> <!-- how about Win7?-->
>> the  NSIS used for packaging the self-installer should
>> be Win7-aware, but I have no Win7-box for testing the
>> installer.
> ok. we will wait for a report of a positive experience before claiming that
> we support it.
> Hamish
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
___________________________________________________________
Preisknaller: WEB.DE DSL Flatrate für nur 16,99 Euro/mtl.!
http://produkte.web.de/go/02/
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20091221/24947cca/smime.bin
