[GRASS-dev] Re: Wingrass-Installer + Win7
Massimo Di Stefano massimodisasha at gmail.com
Mon Dec 21 15:28:31 EST 2009
Thanks Helmut,
i means somethinbg "windows specific".
i know this script, i can try to adjust them a bit
beacouse they uses a lot of d.x command (not avaiable on wingrass)
Ciao,
Massimo.
Il giorno 21/dic/2009, alle ore 20.04, Helmut Kudrnovsky ha scritto:
>> -----Ursprüngliche Nachricht-----
>> Von: "Massimo Di Stefano" <massimodisasha at gmail.com>
>> Betreff: Re: [GRASS-dev] Re: Wingrass-Installer + Win7
> hi Massimo
>> i had not to much time to test it, but if you point me to a script to beused as "unit test" maybe based on spearfish, i'll be appy to try it.
>> let me know if you need to test a precise instruction.
>> regards,
>> Massimo.
> there is some kind of "unit test":
> http://trac.osgeo.org/grass/wiki/HowToTestGrass6
> and
> http://trac.osgeo.org/grass/wiki/HowToTestGrass6#SeeAlso
> with tests for raster, vector, interpolation and image processing
> best regards
> Helmut
> Il giorno 21/dic/2009, alle ore 13.18, Hamish ha scritto:
>>>> Modified: grass-web/trunk/grass64/binary/mswindows/index.html
>>>> +<li><I> For Windows XP and Vista, 32 and 64 bit</I> <!-- how about Win7?-->
>>> the  NSIS used for packaging the self-installer should
>>> be Win7-aware, but I have no Win7-box for testing the
>>> installer.
>> ok. we will wait for a report of a positive experience before claiming that
>> we support it.
>> Hamish
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
> ___________________________________________________________
> Preisknaller: WEB.DE DSL Flatrate für nur 16,99 Euro/mtl.!
> http://produkte.web.de/go/02/
