[GRASS-dev] Re: [GRASS GIS] #827: standalone-installer: execution failed on g.proj.exe -p
GRASS GIS trac at osgeo.org
Mon Dec 21 18:11:50 EST 2009
  Reporter:  timmie        |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  normal        |   Milestone:  6.4.0
 Component:  Installation  |     Version:  svn-releasebranch64
Resolution:                |    Keywords:  wingrass
  Platform:  MSWindows XP  |         Cpu:  x86-32
Comment (by hamish):
 > > does it work using the old tcltk GUI?
 Replying to [comment:9 timmie]:
 > Not for me.
 > > can you run 'g.proj -p' from the GRASS+MSys command line prompt?
 > no. see attached acreenshot
 ok, so not a python problem at all, as tcl and the command line do not use
 python.
 it would be better if you could just type out and translate error messages
 for us, especially if it is just one sentence. cheers
 looking at the screenshot I see someing about a missing function in
 libtiff.dll?? That would indicate that it was built for one version of
 libtiff but is finding another, older one.
 Did you have the same problem with the last installer? (Colin, you are
 building on XP, while Helmut is building on Vista, right?)
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/827#comment:12>
