[GRASS-dev] Re: [GRASS-user] DEM creation from stereo pairs
Michael Barton Michael.Barton at asu.edu
Mon Dec 21 23:53:54 EST 2009
Vince,
I just remembered a very useful free program for dealing with images: Hypercube. When I checked it, it looks like the current version makes DEM's from stereo pairs. Also makes anaglyphs. Only seems to be versions for Mac and Windows. No Linux. The PDF docs give a complete description for how to create DEM's (under the "applications" heading).
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
www: www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Dec 14, 2009, at 12:30 AM, Vincent Bain wrote:
> Michael,
> qmake and qmake-qt4 binaries are different. Is the libqt4-dev library
> installed on your system ? If so, there should exist a file called
> qmake-qt4 in /usr/bin/ or somewhere else (maybe try whereis qmake-qt4)
> Did you get to run Stereo ? I'm stuck at the same point as you (even
> with Alt-R available, nothing happens)
> Vincent
> Le dimanche 13 décembre 2009 à 16:57 -0700, Michael Barton a écrit :
>> Hi Vicent,
>> Where here is where I'm at.
>> cmb-MBP-2:dem_2.0 cmbarton$ /usr/local/Trolltech/Qt-4.1.0/bin/qmake
>> cmb-MBP-2:dem_2.0 cmbarton$ make
>> make: *** No rule to make target `dem.rc', needed by `dem.app/Contents/
>> Resources/dem.rc'.  Stop.
>> I have qt 4.4 as default on my system. This doesn't do anything for
>> efoto it seems. 4.1 does seem to get part there not much farther. Here
>> is an example of my output.
>> Michael
>> C. Michael Barton
>> Phone: 480-965-6262
>> Fax: 480-965-7671
>> On Dec 13, 2009, at 6:35 AM, Vincent Bain wrote:
>>> As for the make command, qmake-qt4 will find on its own the
>>> target .pro
>>> files.
>>> So just type:
>>> qmake-qt4
>>> good luck,
>>> Vincent
>>> Le samedi 12 décembre 2009 à 14:43 -0700, Michael Barton a écrit :
>>>> So how do you actually use qmake?
>>>> I do have qt 4.4 and it is in my path (/usr/bin)
>>>> I cd'ed to the directory of an efoto module (dem), and typed the
>>>> following
>>>> qmake
>>>> qmake dem.pro
>>>> qmake -makefile
>>>> qmake -makefile dem.pro
>>>> qmake -makefile -macx dem.pro
>>>> So far, I've had nothing that works
>>>> Any suggestions?
>>>> Michael
>>>> C. Michael Barton
>>>> Phone: 480-965-6262
>>>> Fax: 480-965-7671
>>>> On Dec 12, 2009, at 10:10 AM, Vincent Bain wrote:
>>>>> Compiling from Qt seems quite easy on Linux :
>>>>> after unzipping the source code archive, from within each module
>>>>> directory, you just have to run qmake-qt4 to compile .pro files,
>>>>> then
>>>>> make install in order to create (local) executables.
>>>>> I tried with 'exterior' module, it works fine.
>>>>> Vincent.
>>>>> Le samedi 12 décembre 2009 à 08:31 -0700, Michael Barton a écrit :
>>>>>> Thanks. I'm looking into this. To run on Mac and Linux, one needs
>>>>>> to
>>>>>> compile this from within QT. I haven't done that and don't know
>>>>>> what
>>>>>> is required.
>>>>>> Michael
>>>>>> C. Michael Barton
>>>>>> Change
>>>>>> Phone: 480-965-6262
>>>>>> Fax: 480-965-7671
>>>>>> On Dec 12, 2009, at 2:17 AM, Vincent Bain wrote:
>>>>>>> Michael,
>>>>>>> don't know if it matches your needs as it is not an automatic
>>>>>>> process
>>>>>>> but I remember a long time ago I used e-foto, formerly only
>>>>>>> available on
>>>>>>> windows. It was a very rough photogrammetry station which
>>>>>>> allowed to
>>>>>>> digitize contour lines on the basis of stereo couples. Nowadays I
>>>>>>> see
>>>>>>> the project is still alive and was ported to Qt :
>>>>>>> http://www.efoto.eng.uerj.br
>>>>>>> Hope it can help,
>>>>>>> Bye,
>>>>>>> Vincent
>>>>>>> Le vendredi 11 décembre 2009 à 21:02 -0700, Michael Barton a
>>>>>>> écrit :
>>>>>>>> Can anyone recommend open source tools for creating a DEM from
>>>>>>>> stereo
>>>>>>>> image pairs?
>>>>>>>> Thanks
>>>>>>>> Michael Barton
>>>>>>>> C. Michael Barton
>>>>>>>> Change
>>>>>>>> Phone: 480-965-6262
>>>>>>>> Fax: 480-965-7671
>>>>>>>> _______________________________________________
>>>>>>>> grass-user mailing list
>>>>>>>> grass-user at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
