[GRASS-dev] Issues of 6.5 build on WinXP
Mon Dec 28 12:46:30 EST 2009
Martin Landa wrote:
> >> FYI: I've set this environment variable at the begining of
> >> C:\OSGeo4W\etc\ini\grass.bat file. Setting this variable in the OS control
> >> panel directly may require restart of Windows (but I am not sure) to have
> >> any effect.
> > Unfortunately it's not working on my machine
> > $ env | grep LC_ALL
> > LC_ALL=cs_CZ
> > but wxGUI starts still unlocalized...
> mystery partly solved, during compilation process in not created
> 'locale' directory and 'make' says
> $ make clean; make
> Creating translations (= 'make mo')
> make[1]: Entering directory `/c/OSGeo4W/usr/src/grass6_devel/locale'
> make[1]: Nothing to be done for `mo'.
> make[1]: Leaving directory `/c/OSGeo4W/usr/src/grass6_devel/locale'
> Not sure what is wrong...
First, ensure that you have GNU make 3.81; I wouldn't trust older
versions to handle non-trivial use of "eval".
FWIW, the locale directory from GRASS 6.5 builds fine for me on
Windows (with make 3.81).
