[GRASS-dev] [GRASS GIS] #848: v.in.mapgen: allow direct input from stdin
GRASS GIS trac at osgeo.org
Mon Dec 28 14:02:21 EST 2009
 Reporter:  hamish       |       Owner:  grass-dev at lists.osgeo.org
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  Vector       |     Version:  svn-trunk
 Keywords:  v.in.mapgen  |    Platform:  All
      Cpu:  All          |
 it would be nice if v.in.mapgen could read directly from stdin when
 'input=-'.
 in "matlab" format mode this module can make a vector line map from a two
 column "x y" data-stream, with new lines created whenever a "nan nan" is
 in the stream. this is very useful for creating a line from points without
 bothering with the grass vector ascii format. it might be worth getting
 its own wrapper script as the 'v.in.mapgen -f' command is not obvious for
 this generic task. v.in.points_as_lines or ...?
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/848>
