[GRASS-dev] Re: [GRASS GIS] #843: v.digit broken on new WinGrass release
GRASS GIS trac at osgeo.org
Wed Dec 30 17:15:51 EST 2009
  Reporter:  cnielsen      |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  critical      |   Milestone:  6.4.0
 Component:  Vector        |     Version:  unspecified
Resolution:                |    Keywords:  wingrass,v.digit
  Platform:  MSWindows XP  |         Cpu:  x86-64
Comment (by marisn):
 Replying to [comment:14 glynn]:
 > It would be possible to modify v.digit to use different names (this may
 also need to be done for reset_values(), set_value() and submit() in
 form.c), but I'm still concerned about the potential side-effects of
 linking against lib/form. Personally, I consider cloning F_generate() to
 be the lesser evil.
 > If d.what.vect is the only module which uses lib/form's F_open(), I'd
 consider removing that code from lib/form and putting it in d.what.vect
 instead. That would simplify lib/form and eliminate the Windows issues.
 As removing something from lib/form will break backwards compatability. I
 attached patch that renames v.digit F_ function copies and removes futurer
 duplicate code. Worksforme, needs review.
Ticket URL: <http://trac.osgeo.org/grass/ticket/843#comment:16>
