[GRASS-dev] v.rast.stats wxPython GUI input reading error
Mon Feb 2 16:56:42 EST 2009
Yann Chemin wrote:
> the following error happens with actual SVN. (Debian Lenny system)
>   File "/home/yann/tmp/grass/dist.i686-pc-linux-gnu/etc/python/grass.py", line 568, in raster_info
>     kv[k] = float(kv[k])
> ValueError: invalid literal for float(): 0:00:07.81346
"r.info -s" outputs DMS, when it should probably use decimal (-g uses
decimal for n/s/e/w).
