[GRASS-dev] [GRASS GIS] #479: wxgui mapset access module broken
GRASS GIS trac at osgeo.org
Thu Feb 5 16:47:06 EST 2009
 Reporter:  cmbarton     |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  6.5.0
Component:  wxGUI        |     Version:  svn-develbranch6
 Keywords:  g.mapsets    |    Platform:  Unspecified
      Cpu:  Unspecified  |
 Trying to use the wxPython module to set mapset access raises an error in
 develbranch_6 compiled today from the SVN. I'm guessing that this is the
 same across 6.4 and 7. Here is the error as tested on the Spearfish
 PERMANENT location.
 PERMANENT spatialtech2008 test1 test2 test3 user1
   File "/Applications/Grass/GRASS-6.5.app/Contents/MacOS/etc
 /wxpython/wxgui.py", line 363, in OnMapsets
 dlg = preferences.MapsetAccess(parent=self, id=wx.ID_ANY)
 /wxpython/gui_modules/preferences.py", line 1736, in
 __init__
 self.mapsetlb.LoadData()
 /wxpython/gui_modules/preferences.py", line 1815, in
 LoadData
 stat_info = os.stat(mapsetPath)
 OSError
 [Errno 2] No such file or directory:
 '/Users/Shared/grassdata/spearfish60_test/PERMANENT
 spatialtech2008 test1 test2 test3 user1 '
 Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/479>
