[GRASS-dev] my custom ps.map to ps3.map
E. Jorge Tizado ejtizado at ono.com
Sun Feb 15 09:07:53 EST 2009
Hi Hamish,
I make many changes to the files in ps.map and to avoid conflict with this
standard command I move my custom ps.map to ps3.map.
This ps3.map compile whithout errors in grass6_devel (6.5.svn). Before I send
this addons (or substitute of ps.map) I want debug and improve some part of
code but I like know the opinion and suggestions to improve the command
needed to draw quality maps whitout any other extern software.
The main improvements are:
1. All font has color.
2. All colors are R:G:B (accept named and none, of course).
3. Many dimensions accept unit (milimeters, centimeters and inches, default
points).
- Grid: option of fcolor to look like as ps3_map_grid.jpg (with a border of 2
points)
- Areas: it is possible define style of line to look as 'Geology-262' in
- Lines: it is possible define style to hline to look as 'Railroads' in
- Scalebar: now with fcolor to look as ps3_map_scalebar.jpg
- rlegend and vlegend: with frame and multicolumns work well as
... and more.
Also I send to Grass-Addons server (GRASS7 subdir) i.landsat.toar and
i.topo.corr; They compile without errors in GRASS7 but I can not test because
teh compilation of GRASS_7 give me errors in many files, mainly because:
/usr/local/grass-6.4.0svn/lib/libgrass_I.so: undefined reference to `G_gets'
`G_get_ask_return_msg'
collect2: ld returned 1 exit status
Thank for suggestions and comments
E. Jorge Tizado
Dpto. Biodiversity and Environmental Management
University of León, Spain
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20090215/608acb1d/ps3_map_grid-0001.jpg
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20090215/608acb1d/ps3_map_legend-0001.jpg
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20090215/608acb1d/ps3_map_scalebar-0001.jpg
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20090215/608acb1d/ps3_map_legend2-0001.jpg
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20090215/608acb1d/ps3_map_comments-0001.jpg
