[GRASS-dev] [GRASS GIS] #501: wxgui: g.message getting squashed
GRASS GIS trac at osgeo.org
Fri Feb 20 03:55:02 EST 2009
 Reporter:  hamish     |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect     |      Status:  new
 Priority:  major      |   Milestone:  6.4.0
Component:  wxGUI      |     Version:  6.4.0 RCs
 Keywords:  g.message  |    Platform:  MSWindows XP
      Cpu:  x86-32     |
 trying to run v.in.gpsbabel from wxGUI.
 (OSGeo4W install on windows xp)
 [Run] button -> Command output:
 (date)
 v.in.gpsbabel format=gpx
 which: gpsbabel: unknown command    (ok, it isn't installed)
 ERROR: http://gpsbabel.sourceforge.net
 [date] Command finished (1 sec)
 the full error message should be:
  if [ ! -x "`which gpsbabel`" ] ; then
     g.message -e "The gpsbabel program was not found, please install it
 first.
                   http://gpsbabel.sourceforge.net"
     exit 1
 fi
 it seems the g.message newline is getting squashed into just a \r and the
 bulk of the message is lost?
 svn setting is ok:
 $ svn propget svn:eol-style v.in.gpsbabel
 native
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/501>
