[GRASS-dev] [GRASS GIS] #502: wxgui / osgeo4w: db.describe execution failed
Michael Barton michael.barton at asu.edu
Fri Feb 20 12:37:52 EST 2009
On Feb 20, 2009, at 10:00 AM, <grass-dev-request at lists.osgeo.org> wrote:
> Date: Fri, 20 Feb 2009 10:09:05 -0000
> From: "GRASS GIS" <trac at osgeo.org>
> Subject: [GRASS-dev] [GRASS GIS] #502: wxgui / osgeo4w: db.describe
> 	execution failed
> To: undisclosed-recipients:;
> Message-ID: <040.7806610de8996e5f24c200e36fdf6045 at osgeo.org>
> Content-Type: text/plain; charset="utf-8"
> Reporter:  hamish    |       Owner:  grass-dev at lists.osgeo.org
>     Type:  defect    |      Status:  new
> Priority:  major     |   Milestone:  6.4.0
> Component:  Database  |     Version:  6.4.0 RCs
> Keywords:  osgeo4w   |    Platform:  MSWindows XP
>      Cpu:  x86-32    |
> Hi,
> latest OSGeo4W binary install of 6.4.0rc3 on windows xp.
> using the wxpython GUI.
> Spearfish: add vector map
> select roads. (or any other map)
> don't even press [ok].
> pop up error:
> window title: Error in command execution db.describe.exe
> Execution failed 'db.describe.exe -c --q table=roads driver=dbf
> database=C:/DocumentsandSettings/Hamish/grassdata/spearfish60/
> PERMANENT/dbf/'
> Details:
> Error: Unable to open database
> <C:/DocumentsandSettings/Hamish/grassdata/spearfish60/PERMANENT/dbf/>
> perhaps it is something to do with the spaces being stripped out of
> "DocumentsandSettings" ??
> after that the map renders ok, but I get the same error if I try to
> query
> the vector map.
> querying the elevation.10m raster map spits out some error messages
> to the
> output window but then scrolls away and gives good data. (sorry
> already
> gone, no cut&paste)
> Hamish
Hamish,
Just helped a visiting student install the OSGeo4W GRASS yesterday and
hit several of the issues you mention. This one is easy to work
around, but I don't know how to fix.
The problem is because db.describe won't parse path names with spaces--
at least in our case. When we moved the GRASS database to C:/grassdata
all worked fine.
Michael
