[GRASS-dev] change in make for Mac causes errors in GRASS 6.5 compilation
William Kyngesburye woklist at kyngchaos.com
Wed Feb 25 21:40:38 EST 2009
On Feb 25, 2009, at 7:16 PM, William Kyngesburye wrote:
>> (I know that William has a symlink to aqua TclTk, but I cannot do
>> this because it makes R-Commander fail. I need the x11 version
>> there).
> Fail to build/install or fail to run?  Are you installing a binary r
> commander package or building from source?  A binary shouldn't care
> about any symlinks when it runs.
... unless they built the binary with tcltk at /usr/local/lib...  I
installed R commander (wow, lots of stuff installed!) and I see in the
tcltk2 module that it's linked to /usr/local/lib/libtcl8.5.dylib.
hmmm... As an alternative for GRASS, so it can find and link tcltk
aqua and not interfere with your X11 tcltk, you could set up a
separate folder with the symlinks to the framework:
/usr/local/tcltkaqua/lib/libtcl8.5.dylib -> tcl framework
/usr/local/tcltkaqua/lib/libtk8.5.dylib -> tk framework
configure GRASS with: --with-tcltk-includes="/Library/Frameworks/
Tcl.framework/Headers /Library/Frameworks/Tk.framework/Headers /
Library/Frameworks/Tk.framework/PrivateHeaders" --with-tcltk-libs=/usr/
local/tcltkaqua/lib
Then there's no need to mess with Platform.make.
Then see if the errors in libform continue.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Mon Dieu! but they are all alike.  Cheating, murdering, lying,
fighting, and all for things that the beasts of the jungle would not
deign to possess - money to purchase the effeminate pleasures of
weaklings.  And yet withal bound down by silly customs that make them
slaves to their unhappy lot while firm in the belief that they be the
lords of creation enjoying the only real pleasures of existence....
- the wisdom of Tarzan
