[GRASS-dev] r.proj from GaussBoaga to UTM
Christian Tiso christian.tiso at ing.unitn.it
Thu Feb 26 02:56:14 EST 2009
Thank you markus, you're right, there's no datum definition:
GRASS 6.3.0 (fassaGB):~ > g.proj -w
PROJCS["Transverse Mercator",
     GEOGCS["international",
         DATUM["unknown",
             SPHEROID["International_1924",6378388,297]],
         PRIMEM["Greenwich",0],
         UNIT["degree",0.0174532925199433]],
     PROJECTION["Transverse_Mercator"],
     PARAMETER["latitude_of_origin",0],
     PARAMETER["central_meridian",9],
     PARAMETER["scale_factor",0.9996],
     PARAMETER["false_easting",1500000],
     PARAMETER["false_northing",0],
     UNIT["Meter",1]]
but this is beacause I created a new location from the GUI start panel
of GRASS by choosing the "EPSG code" button and selectiong the 3003
code which should be the one related to the GaussBoaga, Rome 1940
Monte Mario projections.
Where am I wrong? It is not possible to create such a new location
only by choosing the EPSG code?
Thank you for helping me.
Christian Tiso
Il giorno 26/feb/09, alle ore 00:19, Markus Neteler ha scritto:
> On Wed, Feb 25, 2009 at 5:02 PM, Christian Tiso
> <christian.tiso at ing.unitn.it> wrote:
>> Hi,
>> using command r.proj to reproject a raster topographic map from a
>> Gauss
>> Boaga location (EPSG:3003) to a UTM location (EPSG:32632) I obtain
>> a shift
>> error of the reprojected map of about 40-50m in south direction. It
>> is
>> related to the towgs84 bursa wolf parameters?
>> Is this a known bug?
>> I'm using Grass 6.3.0-2 on a Mac Intel with Moretti's Build binaries.
> please post
> g.proj -w
> I assume that the datum definition is lacking or wrong (towgs84).
> Markus
Christian Tiso, collaborator
Department of Civil and Environmental Engineering
University of  Trento
via Mesiano 77, I-38050 Trento, ITALY
http://www.ing.unitn.it/dica
phone: +39 0461 882610
fax:   +39 0461 882672
E-mail: christian.tiso at ing.unitn.it
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20090226/64c4f73f/attachment.html
