[GRASS-dev] large vector problems
Vincent Bain bain at toraval.fr
Thu Feb 26 02:56:31 EST 2009
Hello,
reading this thread, and being sometimes concerned with large vector
files (associated with big related tables), I wonder if it's worth
manually creating indexes (on cat field) : can it be a effective way to
speed up queries, or is the kink elsewhere, at the geometric level (data
handled by grass, not the linked DBMS) ?
Thank you,
Vincent
Le jeudi 26 février 2009 à 08:42 +0100, Markus Metz a écrit :
> Wouter Boasson wrote:
> > Dear Markus, Markus and Jens,
> > My MacBook survived the burn-in test :-) After 29 hours under full load,
> > alternating processor and disk access limited, I got my mega-vector file
> > cleaned. Thank you for the support and suggestions to solve my problems
> > with the large vector cleaning operation!
> Glad to hear that it worked in the end!
> > Although the dataset was cleaned, files of this size are virtually
> > impossible to handle, especially as standard querying, extract and overlay
> > operations with raster datasets simply take too much time.
> There are ways to improve both speed and memory consumption. There are
> hints in the source code and I have some ideas, but this is no easy
> task. The grass vector model is complex, changes need a lot of testing
> before they can be applied. And there are not that many developers
> working on the core grass vector libraries... This will only happen in
> grass7, I guess. Hopefully sometime this year...
> > I'll post a few related issues with mega files that makes working with them
> > very difficult. I'll post them as (separate) enhancements on trac, as they
> > are in my opinion of major importance:
> > -selecting a large vector map from a dropdown box in the wxPython GUI takes
> > a long time
> > -renaming this vector took 25 minutes (PostgreSQL access!)
> > -v.extract is also incredibly slow
> > -removing a vector file with an unreachable PostgreSQL database link does
> > not work, not even in force mode
> > -v.what consuming several GB of RAM only for querying a large vector map??
> Some of the above operations could be improved, but it will take some time.
> > -v.rast.stats suffers from setting masks, extracting polygons and querying,
> > not usefull anymore for vector files this size, this is a particular slow
> > operations
> Try the example script in the help page of r.univar.zonal, available in
> the grass-addons:
> http://grass.osgeo.org/wiki/GRASS_AddOns#r.univar.zonal
> It should be easy to modify it to your needs, it does something very
> similar to v.rast.stats, only faster.
> Best regards,
> Markus M
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
