[GRASS-dev] large vector and indices, speed up db
Markus Metz markus.metz.giswork at googlemail.com
Fri Feb 27 08:19:32 EST 2009
Moritz Lennert wrote:
> Yes, querying the geometries is very slow currently because of the
> fact that the spatial and topological index is kept in memory and not
> on file, so every time you launch an interactive query, it has to
> rebuild it which is very slow on large vectors. See
> http://josef.fsv.cvut.cz/WIKI/grass-osgeo/index.php/GRASS_7_ideas_collection#Radim.27s_TODO_list
Does someone remember the reason why the spatial index is not (no
longer?) written to a file? Once the spatial index is (again?) written
to a file, all that rebuilding could be avoided by reading from the
file, that alone could give a speed increase.
Markus M
