[GRASS-dev] r.los on windows question
Hamish hamish_b at yahoo.com
Sat Feb 28 21:22:30 EST 2009
Benjamin wrote:
> this is a problem with dirty memory allocation that never
> got fixed.
> If anyone wants to have a go at it: use Valgrind on Linux.
> It will tell you exactly where the bad allocations happen.
Markus has done that already; posted to the bug tracker:
  http://trac.osgeo.org/grass/ticket/111
> From memory: the problem can be fixed by delaying the release of memory
> allocated at the start of each run through the main loop.
also if anyone is interested r.viewshed from wiki addons only needs some
cleanup and small bug fixes to have a LOS app which scales a lot better.
Hamish
