TclTk NVIZ - was Re: [GRASS-dev] missing programmer's manual?
Markus Neteler neteler at osgeo.org
Fri Jan 2 02:00:36 EST 2009
On Thu, Jan 1, 2009 at 6:53 PM, Michael Barton <michael.barton at asu.edu> wrote:
> On Jan 1, 2009, at 10:27 AM, Markus Neteler wrote:
>> I guess I found it. The directory should be now populated with PDFs over
>> the next hour.
>> However, NVIZ isn't documented with doxygen, basically the GRASS libs
>> are.
> Is NVIZ documented anywhere?
The TclTk NVIZ not too much (a few README are in the source code).
And NVIZ2 are "only" (luckily) 1500 lines, way easier to follow.
What are you looking for specifically in TclTk NVIZ?
Markus
