[GRASS-dev] Re: [GRASS GIS] #423: "please wait loading attribute data..." and no way to see data..
GRASS GIS trac at osgeo.org
Mon Jan 5 07:19:07 EST 2009
  Reporter:  marchesinivan  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect         |      Status:  closed
  Priority:  major          |   Milestone:  6.5.0
 Component:  wxGUI          |     Version:  svn-develbranch6
Resolution:  fixed          |    Keywords:  attribute data
  Platform:  Linux          |         Cpu:  x86-32
Changes (by marchesinivan):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:1 martinl]:
 > I cannot reproduce this behaviour. wxGUI code is currently under heavy
 development in develbranch_6 and trunk - some problems can occur. Try the
 last revision.
 Thanks Martin..
 You are right...
 whith the last revision the problem is solved!!!
 many thanks
Ticket URL: <http://trac.osgeo.org/grass/ticket/423#comment:2>
