[GRASS-dev] compile error in grass-6.4.0RC1/gui/wxpython
Otto Dassau otto.dassau at gmx.de
Thu Jan 8 06:57:04 EST 2009
thanks Martin, the python-elementtree package was missing as you suggested. Now
there is the wxpython vdigit problem described in gui/wxpython/README. Hopefully
the final hurdle to clear. I get a
/usr/src/packages/BUILD/grass-6.4.0RC1/gui/wxpython/vdigit# make
/usr/lib/gcc/i586-suse-linux/4.3/../../../../i586-suse-linux/bin/ld: cannot find
-lgdi
is there a chance to have another solution for this wxpython vdigit problem,
than to create a symlink to _gdi_.so shared library? This seems to be quite
difficult to solve / implement in a spec file.
Maybe someone already has a solution for that?
kind regards,
 Otto
On Wed, 7 Jan 2009 15:55:14 +0100
Otto Dassau <otto.dassau at gmx.de> wrote:
> Dear developers,
> On Mon, 29 Dec 2008 16:07:30 +0100
> > Dear developers,
> > I wanted to build GRASS 6.4.0 RC1 packages under OpenSuSE 11.0 and got
> > errors
> > in grass-6.4.0RC1/gui/wxpython. I changed into the directory and tried with
> > 'make' again. I attached the error messages, maybe someone can have a look
> > and help?
> after reading and following the README in
> http://svn.osgeo.org/grass/grass/branches/develbranch_6/gui/wxpython/ I still
> get some error messages:
> make[3]: Entering directory
> `/usr/src/packages/BUILD/grass-6.4.0RC1/gui/wxpython' python
> gui_modules/menudata.py
> /usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu > menustrings.py
> Traceback (most recent call last): File "gui_modules/menudata.py", line 24, in
> <module> import elementtree.ElementTree as etree # Python <= 2.4
> ImportError: No module named elementtree.ElementTree
> make[3]: *** [menustrings.py] Error 1
> make[3]: Leaving directory
> make[2]: *** [install_scripts] Error 2
> make[2]: Leaving directory
> make[1]: Leaving directory `/usr/src/packages/BUILD/grass-6.4.0RC1/gui'
> make[1]: Entering directory `/usr/src/packages/BUILD/grass-6.4.0RC1/imagery'
> Maybe someone has an idea what to do here? Is there something else (a python
> module) missing?
> thanks a lot
>   Otto
> > thanks a lot
> >  Otto
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
