[GRASS-dev] compile error in grass-6.4.0RC1/gui/wxpython
Otto Dassau otto.dassau at gmx.de
Fri Jan 9 10:04:34 EST 2009
I have now changed the OpenSuSE build server from GRASS 6.3 to 6.4 RC1. As for
the version 6.3 I commented gui/wxpython/vdigit in gui/wxpython/Makefile to make
it build.
Packages are available for OpenSuSE 10.3, SLE_10, 11.0 and 11.1 i586 and x86_64.
Can you please add this change to http://grass.osgeo.org/download/index.php and
move the OpenSUSE Geo Repository link from 6.3 to 6.4?
thanks a lot
 Otto
On Thu, 8 Jan 2009 15:36:22 +0100
Otto Dassau <otto.dassau at gmx.de> wrote:
> On Thu, 8 Jan 2009 15:20:55 +0100
> "Martin Landa" <landa.martin at gmail.com> wrote:
> > Hi,
> > 2009/1/7 Glynn Clements <glynn at gclements.plus.com>:
> > > Martin Landa wrote:
> > >> > make[3]: Entering directory
> > >> > `/usr/src/packages/BUILD/grass-6.4.0RC1/gui/wxpython' python
> > >> > gui_modules/menudata.py
> > >> > /usr/src/packages/BUILD/grass-6.4.0RC1/dist.i686-pc-linux-gnu >
> > >> > menustrings.py
> > >> > Traceback (most recent call last): File "gui_modules/menudata.py", line
> > >> > 24, in
> > >> > <module> import elementtree.ElementTree as etree # Python <= 2.4
> > >> > ImportError: No module named elementtree.ElementTree
> > >> in Debian it's python-elementtree.
> > > What? As in, they renamed the module so it doesn't work?
> > > elementtree.ElementTree (xml.etree.ElementTree in >= 2.5) is part of
> > > the core Python library, which is expected to be installed alongside
> > > Python.
> > hm, it seems to me that if you are using python <= 2.4 you need to
> > install python-elementtree package - at least on Debian.
> the problem above occurs with opensuse 11.0 (python 2.5.2). Maybe this
> information is helpful:
> http://lists.opensuse.org/opensuse-factory/2007-02/msg00177.html
>  Otto
> > Martin
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
