[GRASS-dev] Re: problem with gdal 1.6 framework
Michael Barton michael.barton at asu.edu
Thu Jan 15 01:14:30 EST 2009
I redownloaded the newest versions of the frameworks and recompiled.
It all seems to work OK now.
Now to fix the Python version...
Michael
On Jan 14, 2009, at 9:32 PM, William Kyngesburye wrote:
> Which version of the framework?  It should be good in 1.6.0-3.
> On Jan 14, 2009, at 9:17 PM, Michael Barton wrote:
>> William,
>> The gdal 1.6 framework has a postgreSQL dependency that makes it
>> fail when doing any kind of translation, like saving the display.
>> Error:
>> Could not create PNG: dyld: Library not loaded: /usr/local/pgsql/
>> lib/libpq.5.dylib
>> Referenced from /Library/Frameworks/GDAL.framework/Versions/1.6/
>> unix/bin/gdal_translate
>> Reason: image not found
>> (the last error is a TclTk error because gdal_translate doesn't work)
>> Michael
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Time is an illusion - lunchtime doubly so."
> - Ford Prefect
