[GRASS-dev] gmath and gpde update
Thu Jan 15 15:35:12 EST 2009
Soeren Gebbert wrote:
> I may found a way to avoid licensing problems or the need to
> convince the meschach developers to change there license
> to be compatible with the gpl.
> We can use parts of the ccmath library.
> http://freshmeat.net/projects/ccmath/
> The ccmath library is licensed under the LGPL,
> and i hope we don't face any problems with this license?
No. Linking definitely isn't a problem (even proprietary code can link
against LGPL libraries). It appears to be LGPL-2, so we can also
incorporate code directly into GRASS.
