[GRASS-dev] Re: [GRASS GIS] #434: python swig bindings for 7.0 svn noyt working on ubuntu install
GRASS GIS trac at osgeo.org
Fri Jan 16 04:57:30 EST 2009
  Reporter:  mulligan  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  major     |   Milestone:  7.0.0
 Component:  Python    |     Version:  svn-trunk
Resolution:            |    Keywords:  python swig
  Platform:  Linux     |         Cpu:  x86-32
Comment (by glynn):
 Replying to [ticket:434 mulligan]:
 > I have successfully built grass 7.0 svn today on ubuntu 8.04 and it
 works fine.  I have followed the instructions here
 http://svn.osgeo.org/grass/grass/trunk/swig/python/README to make the
 python swig bindings with the output given below
 > The process does noy seem to build the python_grass7.py required and so
 when i run python test.py as indicated I get this:
 The Python bindings have recently been split into multiple packages, one
 for each GRASS library, but the test script wasn't updated.
 Fixed in r35429.
Ticket URL: <http://trac.osgeo.org/grass/ticket/434#comment:1>
