[GRASS-dev] Re: [GRASS GIS] #163: g.transform no longer calculating error for 2nd order transformation
Michael Barton michael.barton at asu.edu
Sat Jan 17 12:04:12 EST 2009
I was able to test a bit.
RMS error reports all 0 for 6 points in a 2nd order transformation.
But the rectification happens OK. RMS values are reported for a 2nd
order transformation with more than 6 points.
Michael
> transformation
>  Reporter:  cmbarton  |       Owner:  grass-dev at lists.osgeo.org
>      Type:  defect    |      Status:  closed
>  Priority:  major     |   Milestone:  6.4.0
> Component:  default   |     Version:  svn-develbranch6
> Resolution:  fixed     |    Keywords:  g.transform georectify
>  Platform:  All       |         Cpu:  Unspecified
> Changes (by hamish):
>  * status:  reopened => closed
>  * resolution:  => fixed
> Comment:
> Replying to [comment:10 martinl]:
>> Any reason why this ticket is still open?
> last bits should be done now. (r35450 thru r35454)
> Hamish
> Ticket URL: <https://trac.osgeo.org/grass/ticket/163#comment:11>
> GRASS GIS <http://grass.osgeo.org>
