[GRASS-dev] GRASS 7 swig compile warnings and errors
Markus Neteler neteler at osgeo.org
Mon Jan 19 15:51:32 EST 2009
On Mon, Jan 19, 2009 at 5:19 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> >> >> I get warnings and errors in swig/python/:
>> >> >> grass_wrap.c: In function '_wrap_G_vasprintf':
>> >> >> grass_wrap.c:18166: error: incompatible types in assignment
>> >>       arg3 = *((va_list *)(argp3));
>> > What does the declaration of arg3 look like?
>>   va_list arg3 ;                       <<<----
> So assigning an expression of type va_list to a variable of type
> va_list results in an "incompatible types in assignment" error from
> the compiler?
> I can only suggest taking this up with the gcc maintainers; I have no
> clue.
I found this:
http://www.swig.org/Doc1.3/SWIGDocumentation.html#Varargs_nn8
-> 13.7 Wrapping of va_list
I don't know if that's related. Also this from a ruby list:
http://rubyforge.org/pipermail/ruby-vpi-discuss/2007-August/000008.html
... mentioning a "type mismatch" error.
BTW, I am using gcc version 4.3.2 on 64bit. Is it only me having
this problem to compile swig/python/ ?
Markus
