[GRASS-dev] Re: [GRASS GIS] #456: Undefined references when building grass 6.4 rc2
GRASS GIS trac at osgeo.org
Fri Jan 23 16:41:07 EST 2009
  Reporter:  fundawang  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect     |      Status:  reopened
  Priority:  major      |   Milestone:  6.4.0
 Component:  default    |     Version:  6.4.0 RCs
Resolution:             |    Keywords:
  Platform:  Linux      |         Cpu:  x86-64
Comment (by glynn):
 Replying to [comment:6 glynn]:
 > This error, and its "fix", are bogus.
 My mistake; the cairodriver change (the one which I tested) is bogus, but
 the rest are legitimate (i.e. the library uses functions from the math
 library directly).
 However, I think that it's probably better to just add $(MATHLIB) to the
 linking command in Shlib.make. Compile.make already do this for
 executables (which is why it has never caused problems before), but not
 for shared libraries.
Ticket URL: <http://trac.osgeo.org/grass/ticket/456#comment:10>
