[GRASS-dev] [GRASS GIS] #461: v.db.update crashes with updating shapefile connected with v.external
GRASS GIS trac at osgeo.org
Sat Jan 24 08:05:07 EST 2009
 Reporter:  msieczka  |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:  6.4.0
Component:  Vector    |     Version:  svn-develbranch6
 Keywords:            |    Platform:  Linux
      Cpu:  x86-64    |
 Backtrace:
 GRASS 6.5.svn (javier):~ > gdb v.to.db
 GNU gdb 6.8-debian
 Copyright (C) 2008 Free Software Foundation, Inc.
 License GPLv3+: GNU GPL version 3 or later
 <http://gnu.org/licenses/gpl.html>
 This is free software: you are free to change and redistribute it.
 There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
 and "show warranty" for details.
 This GDB was configured as "x86_64-linux-gnu"...
 (gdb) run map=gshhs_shp opt=area units=k col=AREA
 Starting program: /usr/local/grass-6.5.svn/bin/v.to.db map=gshhs_shp
 [Thread debugging using libthread_db enabled]
 warning: Lowest section in /usr/lib/libicudata.so.38 is .hash at
 0000000000000120
 [New Thread 0x7fe8946c9710 (LWP 9814)]
 Reading areas...
  100%
 Program received signal SIGSEGV, Segmentation fault.
 [Switching to Thread 0x7fe8946c9710 (LWP 9814)]
 0x00007fe89418f539 in db_get_column_sqltype (column=0x0) at column.c:107
 107         return column->sqlDataType;
 (gdb) bt
 #0  0x00007fe89418f539 in db_get_column_sqltype (column=0x0) at
 column.c:107
 #1  0x00007fe8938f480d in db_select_int (driver=0x9237ba0, tab=0x98bb7f0
 "gshhs", col=0x98b8ba0 "", where=0x0, pval=0x7fff9c7ff858) at select.c:138
 #2  0x00000000004069f2 in update (Map=0x7fff9c7ff8c0) at update.c:53
 #3  0x00000000004043e4 in main (argc=5, argv=0x7fff9c7fffd8) at main.c:84
Ticket URL: <http://trac.osgeo.org/grass/ticket/461>
