[GRASS-dev] Re: [GRASS GIS] #676: r.watershed: different output map options do not allow for fully qualified map names
GRASS GIS trac at osgeo.org
Sun Jul 5 23:16:59 EDT 2009
map names
  Reporter:  mlennert  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  normal    |   Milestone:  6.4.0
 Component:  Raster    |     Version:  6.4.0 RCs
Resolution:            |    Keywords:  r.watershed
  Platform:  Linux     |         Cpu:  Unspecified
Changes (by hamish):
  * keywords:  r.mapcalc => r.watershed
  * component:  default => Raster
Comment:
 you may only write to the current mapset. therefore @othermapset is not
 needed for output maps.
 if it is given, and the value is the current mapset, then perhaps it
 should be quietly ignored. hopefully it could be done at the library
 level. if it can't be handled at the lib level I'd be inclined to ignore
 it rather than add clutter to all raster modules.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/676#comment:1>
