[GRASS-dev] Re: grass-dev Digest, Vol 39, Issue 18
Tue Jul 7 09:49:25 EDT 2009
Michael Barton wrote:
> >> perhaps default to ~/.grass/addons/ ?
> >> (together with rename of .grassrc7 in trunk (it's not a rc file).
> >> call that ~/.grass/init ? or?)
> > I like the idea of `.grass` directory. There is also .grasswx7 which
> > could be moved to `.grass/wx`.
> For some crazy reason directories starting with "." are invisible to
> normal Mac users. For a Mac, it would be better to have this in /
> Library/Application Support/Grass.
Wouldn't that be system-wide? It should be per-user.
