[GRASS-dev] Re: [GRASS GIS] #676: r.watershed: different output map options do not allow for fully qualified map names
GRASS GIS trac at osgeo.org
Wed Jul 8 11:27:52 EDT 2009
map names
  Reporter:  mlennert  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  normal    |   Milestone:  6.4.0
 Component:  Raster    |     Version:  6.4.0 RCs
Resolution:            |    Keywords:  r.watershed
  Platform:  Linux     |         Cpu:  Unspecified
Comment (by glynn):
 Replying to [comment:9 hamish]:
 > The problem is not G_legal_filename(). The problem is that you should
 not under normal circumstances be passing fully qualified map names to
 output= options.
 Regardless of whether anything should or should not be doing this, passing
 a qualified map name for output maps is legal, so long as the mapset is
 the current mapset. E.g. G!__open_raster_new() will happily accept
 map at mapset provided that mapset==G_mapset().
 > And if you do, it would be useful for something* to strip it away, and
 exit with an error if the value given was not the current mapset.
 > [*] hopefully that something is done at the library level so a new fn()
 wouldn't have to be added to all modules, either in G_parser() or in the
 opening of a new map for write. I understand that opening a new map to
 write might be downstream of a G_legal_filename() check already in the
 module, but if you say that is already "cleaned" in GRASS 7 then all that
 needs to be done there is add the @ stripping code to either/both of
 G_parser() and or whatever the Rast_open_new_cell for write fn name is
 called now.
 There's no need to strip anything. Library functions should always accept
 qualified map names. For output maps, the mapset must be the current
 mapset, and unqualified names should use the current mapset rather than
 the mapset search path (which isn't required to include the current
 mapset).
 The main problem is individual modules getting in the way and attempting
 to enforce bogus rules.
Ticket URL: <https://trac.osgeo.org/grass/ticket/676#comment:12>
