[GRASS-dev] Re: comparing r.cost and r.terracost [was: Re: [GRASS-user] affecting cat of closest feature as pixel value]
Laura Toma ltoma at bowdoin.edu
Wed Jul 15 09:40:22 EDT 2009
Hi Moritz,
Terracost  runs in two modes:  in memory (when numtiles=1), and in
external memory, using streams (when numtiles>1).   When run without a
value for numtiles, it sets numtiles  to the optimal value. In all
your tests numtiles was set to 1.   The algorithms in the 2 cases are
different, so you also need to test with numtiles>1.
The difference in speed should increase a lot with the size of the
raster.
> In the idea of replacing r.cost by r.terracost, I would think that
> the latter would first have to implement the options in r.cost, e.g.
> - equivalents of the start_points and coordinates options of r.cost
> - stop_points/coordinates
> - max_cost
> - the knight's move
What does the max_cost do ?
I can easily add the  Knight's move;  is it generally agreed that it
is a useful option?  Without the Knight's move, each point can get to
its 8 neighbors in one step. With the Knight's move, it can get to
some additional points, which it was going to reach in two steps, at a
slightly higher cost.
The other options are in principle easy to add, but time  is the
problem..
-Laura
On Jul 15, 2009, at 6:22 AM, Moritz Lennert wrote:
> Hello Laura,
> On 15/07/09 00:01, Laura Toma wrote:
>> Hi Markus, Moritz,
>> I could reproduce the problem. It was happening because the cost of
>> the source points were incorrectly assigned to be zero, instead of
>> the actual cost of the points.  Because of  this, the immediate
>> neighbors of the source points had "half" costs.  I fixed one line
>> in initialize.cc and checked in the change in grass-addons/raster/
>> r.terracost   (hopefully it is  the right place).
> yes, perfect. Thanks for fixing this so quickly. Now results are
> almost identicial to r.cost without the knight's move. Differences
> are very small, and (my guess) probably due to differences in
> rounding:
> g.region n=10 s=0 w=0 e=10 res=1 -a
> r.mapcalc one=1.0
> echo "5|5" | v.in.ascii out=start --o
> v.to.rast start use=val val=1 out=start --o
> time r.cost one start_rast=start out=r_cost --o
> time r.terracost one start_rast=start out=terra_cost --o
> r.mapcalc diff3=r_cost-terra_cost
> r.univar diff
> n: 100
> minimum: -1.90012e-07
> maximum: 1.91819e-07
> range: 3.81831e-07
> mean: -4.1721e-09
> And image of diff:
> http://geog-pc40.ulb.ac.be/grass/misc/
> This seems to indicate that r.cost "overestimates" diagonals and
> "underestimates" the straighter lines when compared to r.terracost.
> The same, but with a 100x100 region:
> r.univar diff:
> n: 10000
> minimum: -3.04995e-05
> maximum: 9.16214e-06
> range: 3.96616e-05
> mean: 6.50277e-07
> And image of diff:
> This seems to confirm the above, but not for farther distances...
> Second test:
> g.region rast=elev_state_500m
> v.to.rast nc_state use=val val=500.0 out=cost --o
> v.to.rast urbanarea use=val val=1 out=urbanarea --o
> r.cost in=cost start_rast=urbanarea out=dist_urban --o
> r.terracost in=cost start_rast=urbanarea out=dist_urban_terracost --o
> r.mapcalc diff=dist_urban-dist_urban_terracost
> r.univar diff
> n: 513065
> minimum: -0.0125342
> maximum: 0.0684331
> range: 0.0809673
> mean: 0.00173129
> Third test:
> g.region rast=landclass96
> r.reclass landclass96 out=cost_landcover --o << EOF
> 1 = 200
> 2 = 20
> 3 = 5
> 4 = 50
> 5 = 30
> 6 = 1000
> 7 = 5
> EOF
> echo "629980|228527.25" | v.in.ascii out=point --o
> v.to.rast point use=val val=1 out=point --o
> r.cost in=cost_landcover out=dist_rcost start_rast=point --o
> r.terracost in=cost_landcover out=dist_terracost start_rast=point --o
> r.mapcalc diff2=dist_rcost-dist_terracost
> r.univar diff2
> n: 249323
> minimum: -0.554688
> maximum: 0.523438
> range: 1.07812
> mean: -0.0104599
> In all cases r.terracost takes about 1/4-1/3 the time of r.cost.
> - max_cost
> - the knight's move
> Moritz
