[GRASS-dev] GRASS 7: Rast__allocate_null_bits() and Rast__null_bitstream_size()?
Sun Jul 19 23:47:10 EDT 2009
Markus Neteler wrote:
> in GRASS 7, I found that
> are used in r.null and r.support.
> Question: why Rast__xxx() and not Rast_xxx()?
That's the convention for functions which are meant for internal use
only.
The only code which needs to use those functions is code which reads
or writes the null bitmap file directly. The "public" interface to the
null bitmap (e.g. Rast_get_null_value_row()) expands the bitmap to one
byte per cell.
Arguably, lib/raster needs e.g. Rast_create_null_bitmap() so that
r.null and r.support don't need to access the file directory.
OTOH, 7.0 is a good opportunity to eliminate the null bitmap
altogether.
