[GRASS-dev] 7.svn fails to build from source (solved/doh!)
Tue Jul 21 06:48:29 EDT 2009
Hamish wrote:
> OT: can tools/sql.sh be adapted to work with SQLite as the target DB?
AFAICT, you would need to replace the \copy commands with .import (and
change the .lst format to match), and replace SELECT ... INTO with
CREATE TABLE ... AS.
