[GRASS-dev] Re: [Qgis-developer] edting non active qgis/grass layers
Maciej Sieczka msieczka at sieczka.org
Mon Jul 27 08:39:05 EDT 2009
Giovanni Manghi pisze:
>> GRASS "layers" in a GRASS "vector map" have *common geometry*. You can't
>> edit the geometry of one GRASS "layer" not interfering with the
>> geometry of the other "layer" in a single "vector map".
>> This is different than in case of e.g. shapefiles, where each layer is a
>> set of files dedicated only to a particular layer, thus when you edit
>> it, you do so only for this particular layer.
>> GRASS "layers" and OGR "layers" are different things.
> I understand (I already knew what was the difference), but that wasn't
> my point.
Ok then I didn't get your point.
Maciek
Maciej Sieczka
http://www.sieczka.org
