[GRASS-dev] erorrs compiling i.pr modules
Moskovitz, Bob Bob.Moskovitz at conservation.ca.gov
Tue Jul 28 14:14:57 EDT 2009
I ran into this problem before.  I believe the api has changes for a 2 argument Vect_build to a one.  See what happens when you remove the second one.
Bob Moskovitz
Research Analyst I
Seismic Hazard Evaluation Project
California Geological Survey
http://gmw.consrv.ca.gov/shmp
CONFIDENTIALITY NOTICE: This communication is intended only for the use of the individual or entity to which it is addressed. This message contains information from the State of California, California Geological Survey, which may be privileged, confidential and exempt from disclosure under applicable law, including the Electronic Communications Privacy Act. If the reader of this communication is not the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication is strictly prohibited.
> -----Original Message-----
> From: grass-dev-bounces at lists.osgeo.org
> [mailto:grass-dev-bounces at lists.osgeo.org]On Behalf Of Dylan Beaudette
> Sent: Tuesday, July 28, 2009 10:08 AM
> To: grass-dev at lists.osgeo.org
> Subject: [GRASS-dev] erorrs compiling i.pr modules
> Hi,
> Just updates to today's GRASS65-SVN, and checked out the
> grass-addons SVN
> tree. I was able to compile several of the modules, but the
> i.pr modules seem
> to be failing with the following error:
> i.pr_sites_aggregate
> make[1]: Entering directory
> `/home/dylan/src/grass_6/grass-addons/imagery/i.pr/i.pr_sites_
> aggregate'
> test -d OBJ.i686-pc-linux-gnu || mkdir -p OBJ.i686-pc-linux-gnu
> gcc -I/home/dylan/src/grass_6/dist.i686-pc-linux-gnu/include
> -g -O2    -I../include/   -DPACKAGE=\""grassmods"\"
> -I/home/dylan/src/grass_6/dist.i686-pc-linux-gnu/include -o
> OBJ.i686-pc-linux-gnu/main.o -c main.c
> main.c: In function ‘main’:
> main.c:233: error: too many arguments to function ‘Vect_build’
> main.c:235: error: too many arguments to function ‘Vect_build’
> make[1]: *** [OBJ.i686-pc-linux-gnu/main.o] Error 1
> make[1]: Leaving directory
> aggregate'
> Any ideas, or suggestions on further information I can
> provide that would
> help?
> Cheers,
> Dylan
> Dylan Beaudette
> Soil Resource Laboratory
> http://casoilresource.lawr.ucdavis.edu/
> University of California at Davis
> 530.754.7341
> grass-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-dev
