[GRASS-dev] GRASS 7: r.in.wms compile failure - ImportError: cannot import name log
Hamish hamish_b at yahoo.com
Tue Jun 2 15:32:52 EDT 2009
Markus:
> > Interestingly it works today. Perhaps I had set
> > $PYTHONPATH indeed to the swig/python/ directory as
> > suggested in the examples:
Glynn:
> Right; that will cause the problem which you reported.
> The only GRASS-related directory which should be added to
> PYTHONPATH is $GISBASE/etc/python.
fwiw, this fix was committed to 6.4 and 6.5 svns 2 days ago:
http://trac.osgeo.org/grass/changeset/37641
Hamish
