[GRASS-dev] Re: [GRASS GIS] #629: WinGRASS: spaces in pathnames
GRASS GIS trac at osgeo.org
Sat Jun 6 13:39:32 EDT 2009
  Reporter:  hamish        |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  normal        |   Milestone:  6.4.0
 Component:  Installation  |     Version:  6.4.0 RCs
Resolution:                |    Keywords:  wingrass, msys
  Platform:  MSWindows XP  |         Cpu:  x86-32
Comment (by glynn):
 Replying to [ticket:629 hamish]:
 > trying the native stand-alone installer (rev37703) installed in
 > C:\Program Files\GRASS GIS\GRASS-6-SVN to expose/fix some missing
 quoting.
 > The icon to start the wxPython GUI directly works, but the Cmd> prompt
 fails for `v.db.select roads where="label ~ 'highway'"` with:
 Bad file descriptor: Files/GRASS
 This one isn't an MSys issue, as MSys shouldn't be involved in running the
 wxPython GUI, or in running commands from it.
 Did the shlex fix make it into the version which you're testing?
Ticket URL: <https://trac.osgeo.org/grass/ticket/629#comment:4>
