[GRASS-dev] Re: [GRASS GIS] #625: make errors (missing demolocation)
GRASS GIS trac at osgeo.org
Tue Jun 9 15:15:48 EDT 2009
  Reporter:  cnielsen         |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect           |      Status:  new
  Priority:  critical         |   Milestone:  7.0.0
 Component:  default          |     Version:  svn-trunk
Resolution:                   |    Keywords:
  Platform:  MSWindows Vista  |         Cpu:  x86-32
Comment (by cnielsen):
 Sorry Glynn, I had rolled back to an earlier version and that is why the
 demolocation error seemed fixed. In fact the patch had no effect, the
 error is still present.
 /src/trunk/db/db.columns
 $ make
 if [ "/src/trunk/dist.i686-pc-mingw32/bin/db.columns.exe" != "" ] ; then
 GISRC=/src/trunk/dist.i686-pc-mingw32/demolocation/.grassrc70
 GISBASE=c:/programs/gis/osgeo4w/usr/src/trunk/dist.i686-pc-mingw32
 PATH="/src/trunk/dist.i686-pc-mingw32/bin:$PATH"
 PYTHONPATH="c:\programs\gis\osgeo4w\usr\src\trunk\dist.i686-pc-
 mingw32\etc\python;$PYTHONPATH" PATH="/src/trunk/dist.i686-pc-
 mingw32/bin:/src/trunk/dist.i686-pc-mingw32/lib:/src/trunk/dist.i686-pc-
 mingw32/lib:.:/usr/local/bin:/mingw/bin:/bin:/osgeo4w/bin:/c/Windows/system32:/c/Windows:/c/Windows/System32/Wbem:/c/PROGRA~1/COMMON~1/ULEADS~1/MPEG:/c/Programs/GIS/Subversion:/c/Programs/Online/QuickTime/QTSystem/:/osgeo4w/apps/grass/bin:/bin:/c/Programs/Subversion"
 LC_ALL=C /src/trunk/dist.i686-pc-mingw32/bin/db.columns.exe --html-
 description < /dev/null | grep -v '</body>\|</html>' > db.columns.tmp.html
 ; fi
 access: No such file or directory
 ERROR: LOCATION << /src/trunk/dist.i686-pc-mingw32/demolocation >> not
        available
 make: *** [db.columns.tmp.html] Error 1
 rm db.columns.tmp.html
Ticket URL: <http://trac.osgeo.org/grass/ticket/625#comment:5>
