[GRASS-dev] GRASS and C++
Wed Jun 10 10:54:29 EDT 2009
Wolf Bergenheim wrote:
> >> I just read on the development Wiki that there is limited support for
> >> C++ and was hoping someone could clarify that. If I'm writing a module
> >> can I use C++?
> > You're welcome to try. The main issue is that most of the configure
> > checks are performed using the C compiler, and any Makefile variables
> > are set appropriately for the C compiler.
> Also note that there is no default rule to build C++ files into .o files
Yes there is; see Rules.make (6.x) or Compile.make (7.0).
