[GRASS-dev] r.in.gdal problems
Laura Toma ltoma at bowdoin.edu
Wed Jun 10 11:14:31 EDT 2009
I imported a large SRTM grid with r.in.gdal;  when starting grass64
with this location there is an error.
Some part of Grass seems to work despite this error, except d.rast
shows a blank screen.  The east and west (see below)  have the same
value, except E/W. Could this cause troubles?
GRASS 6.4.0RC4 (northamericaSRTM3):~/gis/DATA/SRTM/SRTM-V2-
frome0srp01u.ecs.nasa.gov/SRTM3/north_america > Error in startup
script: divide by zero
     while executing
"expr round($parts(w)/$parts(ewres))*$parts(ewres)"
     (procedure "MapCanvas::zoom_gregion" line 17)
     invoked from within
"MapCanvas::zoom_gregion $mon"
     (procedure "MapCanvas::create" line 40)
     invoked from within
"MapCanvas::create"
     (procedure "Gm::startmon" line 11)
     invoked from within
"Gm::startmon"
     (procedure "Gm::create" line 79)
     invoked from within
"Gm::create"
     (procedure "main" line 30)
     invoked from within
"main $argc $argv"
     (file "/usr/local/grass/grass-6.4.0RC4/etc/gm/gm.tcl" line 566)
frome0srp01u.ecs.nasa.gov/SRTM3/north_america > g.region -p
projection: 3 (Latitude-Longitude)
zone:       0
datum:      wgs84
ellipsoid:  wgs84
north:      61:00:01.5N
south:      9:59:58.5N
west:       179:59:58.5E
east:       179:59:58.5W
nsres:      0:00:03
ewres:      0:00:00.000007
rows:       61201
cols:       432001
cells:      26438893201
frome0srp01u.ecs.nasa.gov/SRTM3/north_america > r.info na_mosaic
  | Layer:    na_mosaic                      Date: Tue Jun  9 21:54:39
2009    |
  | Mapset:   PERMANENT                      Login of Creator:
ltoma           |
northamericaSRTM3                                                |
  | DataBase: /mnt/research/gis/DATA/
grassdb/                                  |
  | Title:
( na_mosaic )                                                   |
  | Timestamp:
none                                                            |
  |   Type of Map:  raster               Number of Categories:
5573            |
  |   Data Type:
CELL                                                       |
  |   Rows:
61201                                                      |
  |   Columns:
432001                                                     |
  |   Total Cells:
26438893201                                                |
  |        Projection: Latitude-
Longitude                                      |
  |            N: 61:00:01.5N    S: 9:59:58.5N   Res:
0:00:03                  |
  |            E: 179:59:58.5W    W: 179:59:58.5E   Res:
0:00:00.000007        |
  |   Range of data:    min = -291  max =
5573                                 |
  |   Data
Description:                                                        |
  |    generated by
r.in.gdal                                                  |
Comments
  |    r.in.gdal input="na_mosaic.vrt"
output="na_mosaic"                      |
-Laura
