[GRASS-dev] calculate distance with vector
    Moritz Lennert
    mlennert at club.worldonline.be
    Wed Jun 10 15:15:22 EDT 2009
On 10/06/09 17:16, Quentin Page wrote:
> hi,
> I want to know what are distances between several little vectors and the
> big one.
> so I write :
> v.distance -p -a from=grille247 at ventoux288 to=roland3 at ventoux288
> from_type=centroid to_type=boundary from_layer=1 to_layer=1 dmax=-1
> upload=cat,dist table=cat,dist
> the little vectors are in grille247 and they contain lots of another
> information.
> the error is
> Required parameter <column> not set:
> (Column name(s) where values specified by 'upload' option will be uploaded)
> how can i set the column.
Just use column=cat,dist (or whatever names you want) instead of
table=cat,dist. The table= parameter allows you to set the name of a
table that will be created when using the -a flag to get complete
distance matrices.
However, in your case, as you use the -p flag, no table will be created
and results just sent to standard output. However, it still needs the
column= parameter set to know how to name the output columns. I do think
that v.distance could just use sensible default names (i.e. the names of
  the different options of the upload= parameter - with the exception of
cat, which should be called to_cat to avoid naming conflicts).
Moritz
