[GRASS-dev] Re: [GRASS GIS] #637: Problems with paths in the TCL/TK Windows GUI
GRASS GIS trac at osgeo.org
Thu Jun 11 12:36:00 EDT 2009
  Reporter:  marmai        |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  critical      |   Milestone:  6.4.0
 Component:  Tcl           |     Version:  6.4.0 RCs
Resolution:                |    Keywords:  Tcl Window Gui path, wingrass
  Platform:  MSWindows 2K  |         Cpu:  Unspecified
Comment (by hamish):
 > Replying to [comment:5 hamish]:
 > > Ok, so the code we need to check then is the bit that launches
 > > e.g. dbf.exe child from lib/db/dbmi_client/start.c  ???
 Replying to [comment:6 glynn]:
 > I don't think so. The backslashes are getting lost.
 (comment:4 of this ticket reports that fixed now)
 > Windows' command interpreter doesn't interpret backslashes, so
 > this looks more like Tcl's doing. It looks like something is
 > (implicitly or explicitly) using "eval" or "subst" on the string,
 > causing backslash-<char> to be replaced with <char>.
 maybe fixed by the new `eval [list ]` stuff?
 anyway I was more thinking about the ''Bad file descriptor'' problems of
 unquoted spaces from https://trac.osgeo.org/grass/ticket/629#comment:5,
 not the missing '\'s.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/637#comment:7>
