[GRASS-dev] [GRASS GIS] #647: v.generalize's remove_small deletes wrong boundary
GRASS GIS trac at osgeo.org
Sun Jun 14 17:44:35 EDT 2009
 Reporter:  hoeth    |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect   |      Status:  new
 Priority:  normal   |   Milestone:  6.4.0
Component:  default  |     Version:  unspecified
 Keywords:           |    Platform:  Linux
      Cpu:  x86-64   |
 Running v.generalize method=remove_small on the boundaries in
 "working.ascii" and "broken.ascii" yields different results, even though
 the only difference between the two files is the order in which the
 boundaries are stored. For "working.ascii" only the small open boundary is
 removed, while for "broken.ascii" both boundaries are removed.
 I observe this behaviour both in 6.3.0 and in 6.4.0RC5 (didn't try any
 other releases).
Ticket URL: <http://trac.osgeo.org/grass/ticket/647>
