[GRASS-dev] New WinGrass Release (6.4.0RC5)
Martin Landa landa.martin at gmail.com
Wed Jun 17 09:20:10 EDT 2009
2009/6/17 Hamish <hamish_b at yahoo.com>:
> Martin wrote:
>> the last time I ended up in the hell of mixing libraries built using
>> mingw (GRASS) and msvs (wxpython). Currently I have no time for this
>> kind of "fun". If somebody put on wiki instructions how to overcome
>> this problem I will be happy to fix MS Windows related bugs to make
>> these extensions working under MS Windows.
> have you tried the updated & simplified build instructions using osgeo4w
> as the framework?
> https://trac.osgeo.org/grass/wiki/CompileOnWindows
sure, I followed these instructions - but it doesn't help you to make
the Python extensions working (swig-related failure - probably because
wxPython is built using msvs and GRASS with mingw).
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
