[GRASS-dev] Re: [GRASS GIS] #625: make errors (missing demolocation)
GRASS GIS trac at osgeo.org
Wed Jun 17 17:56:57 EDT 2009
  Reporter:  cnielsen  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  closed
  Priority:  critical  |   Milestone:  7.0.0
 Component:  default   |     Version:  svn-trunk
Resolution:  fixed     |    Keywords:
  Platform:  All       |         Cpu:  All
Comment (by glynn):
 Replying to [comment:12 hamish]:
 > ` \ #comment` is a problem.. causes this to happen when you run
 ./configure:
 configure: warning:  #--with-ffmpeg: invalid host type
 > I don't really understand why ./configure continues weirdly, but if I
 get rid of the `\ #--with-ffmpeg` line it all builds ok.
 bash treats "\ "" as a literal space, not a word separator. This means
 that the following # isn't at the beginning of a word, so it's treated as
 a literal # character rather than starting a comment. The end result is an
 argument of "{{{ #--with-ffmpeg}}}". As it's the first argument which
 doesn't begin with a dash, it's treated as the host type.
Ticket URL: <https://trac.osgeo.org/grass/ticket/625#comment:14>
