[GRASS-dev] Re: [GRASS-user] v.lidar.edgedetection very slow
Jyothish Soman jyothish.soman at gmail.com
Fri Jun 19 14:22:14 EDT 2009
Skipped content of type multipart/alternative-------------- next part --------------
#include <stdlib.h>             /* imported libraries */
2 	#include <stdio.h>
3 	#include <math.h>
4 	#include <grass/gis.h>
5 	#include <grass/PolimiFunct.h>
6 	#include<omp.h>   /*Change here*/
7 	/*--------------------------------------------------------------------------------------*/
8 	/* Tcholetsky decomposition -> T= Lower Triangular Matrix */
9
10 	void tcholDec(double **N, double **T, int n, int BW)
11 	{
12 	    int i, j, k,num_p;
13 	    double somma;
14 	omp_set_num_threads(omp_get_num_procs());
15 	    G_debug(3, "tcholDec(): n=%d  BW=%d", n, BW);
16 	#pragma omp for shared(i,N,BW,T) private(j,k,somma)
17 	    for (i = 0; i < n; i++) {
18 	        G_percent(i, n, 2);
19 	        for (j = 0; j < BW; j++) {
20 	            somma = N[i][j];
21 	            for (k = 1; k < BW; k++)
22 	                if (((i - k) >= 0) && ((j + k) < BW))
23 	                    somma -= T[i - k][k] * T[i - k][j + k];
24 	            if (j == 0) {
25 	                if (somma <= 0.0)
26 	                    G_fatal_error(_("Decomposition failed"));
27 	                T[i][0] = sqrt(somma);
28 	            }
29 	            else
30 	                T[i][j] = somma / T[i][0];
31 	        }
32 	    }
33
34 	    G_percent(i, n, 2);
35 	    return;
36 	}
37
38 	/*--------------------------------------------------------------------------------------*/
39 	/* Tcholetsky matrix solution */
40
41 	void tcholSolve(double **N, double *TN, double *parVect, int n, int BW)
42 	{
43
44 	    double **T;
45 	    int i, j;
46 	omp_set_num_threads(omp_get_num_procs());
47 	        /*--------------------------------------*/
48 	    T = G_alloc_matrix(n, BW);
49
50 	        /*--------------------------------------*/
51 	    tcholDec(N, T, n, BW);      /* T computation                */
52
53 	    /* Forward substitution */
54 	    parVect[0] = TN[0] / T[0][0];
#pragma omp for shared(i,TN,parvect) private(j)
55 	    for (i = 1; i < n; i++) {
56 	        parVect[i] = TN[i];
57 	        for (j = 0; j < i; j++)
58 	            if ((i - j) < BW)
59 	                parVect[i] -= T[j][i - j] * parVect[j];
60 	        parVect[i] = parVect[i] / T[i][0];
61 	    }
62 #pragma omp for shared(i) private()
63 	    /* Backward substitution */
64 	    parVect[n - 1] = parVect[n - 1] / T[n - 1][0];
65 	    for (i = n - 2; i >= 0; i--) {
66 	        for (j = i + 1; j < n; j++)
67 	            if ((j - i) < BW)
68 	                parVect[i] -= T[i][j - i] * parVect[j];
69 	        parVect[i] = parVect[i] / T[i][0];
70 	    }
71
72 	        /*--------------------------------------*/
73 	    G_free_matrix(T);
74
75 	    return;
76 	}
77
78
79 	/*--------------------------------------------------------------------------------------*/
80 	/* Soluzione con Tcholetsky -> la matrice T triangolare viene passata come paramtero e
81 	   non calcolata internamente alla procedura -> T = dmatrix (0, n-1, 0, BW-1) */
82
83 	void tcholSolve2(double **N, double *TN, double **T, double *parVect, int n,
84 	                 int BW)
85 	{
86
87 	    int i, j;
88 	omp_set_num_threads(omp_get_num_procs());
89 	    /* Forward substitution */
90 	    parVect[0] = TN[0] / T[0][0];
91 	    for (i = 1; i < n; i++) {
92 	        parVect[i] = TN[i];
93 	        for (j = 0; j < i; j++)
94 	            if ((i - j) < BW)
95 	                parVect[i] -= T[j][i - j] * parVect[j];
96 	        parVect[i] = parVect[i] / T[i][0];
97 	    }
98
99 	    /* Backward substitution */
100 	    parVect[n - 1] = parVect[n - 1] / T[n - 1][0];
101 	    for (i = n - 2; i >= 0; i--) {
102 	        for (j = i + 1; j < n; j++)
103 	            if ((j - i) < BW)
104 	                parVect[i] -= T[i][j - i] * parVect[j];
105 	        parVect[i] = parVect[i] / T[i][0];
106 	    }
107
108 	    return;
109 	}
110
111 	/*--------------------------------------------------------------------------------------*/
112 	/* Tcholetsky matrix invertion */
113
114 	void tcholInv(double **N, double *invNdiag, int n, int BW)
115 	{
116 	    double **T = NULL;
117 	    double *vect = NULL;
118 	    int i, j, k;
119 	    double somma;
120
121 	        /*--------------------------------------*/
122 	    G_alloc_matrix(n, BW);
123 	    G_alloc_vector(n);
124 	omp_set_num_threads(omp_get_num_procs());
125 	    /* T computation                */
126 	    tcholDec(N, T, n, BW);
127
128 	    /* T Diagonal invertion */
129 	    for (i = 0; i < n; i++) {
130 	        T[i][0] = 1.0 / T[i][0];
131 	    }
132
133 	    /* N Diagonal invertion */
134 	    for (i = 0; i < n; i++) {
135 	        vect[0] = T[i][0];
136 	        invNdiag[i] = vect[0] * vect[0];
137 	        for (j = i + 1; j < n; j++) {
138 	            somma = 0.0;
139 	            for (k = i; k < j; k++) {
140 	                if ((j - k) < BW)
141 	                    somma -= vect[k - i] * T[k][j - k];
142 	            }
143 	            vect[j - i] = somma * T[j][0];
144 	            invNdiag[i] += vect[j - i] * vect[j - i];
145 	        }
146 	    }
147
148 	        /*--------------------------------------*/
149 	    G_free_matrix(T);
150 	    G_free_vector(vect);
151
152 	    return;
153 	}
154
155 	/*--------------------------------------------------------------------------------------*/
156 	/* Tcholetsky matrix solution and invertion */
157
158 	void tcholSolveInv(double **N, double *TN, double *invNdiag, double *parVect,
159 	                   int n, int BW)
160 	{
161
162 	    double **T = NULL;
163 	    double *vect = NULL;
164 	    int i, j, k;
165 	    double somma;
166 	omp_set_num_threads(omp_get_num_procs());
167 	        /*--------------------------------------*/
168 	    G_alloc_matrix(n, BW);
169 	    G_alloc_vector(n);
170
171 	    /* T computation                */
172 	    tcholDec(N, T, n, BW);
173
174 	    /* Forward substitution */
175 	    parVect[0] = TN[0] / T[0][0];
#pragma omp for shared(i) private(j)
176 	    for (i = 1; i < n; i++) {
177 	        parVect[i] = TN[i];
178 	        for (j = 0; j < i; j++)
179 	            if ((i - j) < BW)
180 	                parVect[i] -= T[j][i - j] * parVect[j];
181 	        parVect[i] = parVect[i] / T[i][0];
182 	    }
183
184 	    /* Backward substitution */
185 	    parVect[n - 1] = parVect[n - 1] / T[n - 1][0];
186 	    for (i = n - 2; i >= 0; i--) {
187 	        for (j = i + 1; j < n; j++)
188 	            if ((j - i) < BW)
189 	                parVect[i] -= T[i][j - i] * parVect[j];
190 	        parVect[i] = parVect[i] / T[i][0];
191 	    }
192
193 	    /* T Diagonal invertion */
194 	    for (i = 0; i < n; i++) {
195 	        T[i][0] = 1.0 / T[i][0];
196 	    }
197
198 	    /* N Diagonal invertion */
199 	    for (i = 0; i < n; i++) {
200 	        vect[0] = T[i][0];
201 	        invNdiag[i] = vect[0] * vect[0];
202 	        for (j = i + 1; j < n; j++) {
203 	            somma = 0.0;
204 	            for (k = i; k < j; k++) {
205 	                if ((j - k) < BW)
206 	                    somma -= vect[k - i] * T[k][j - k];
207 	            }
208 	            vect[j - i] = somma * T[j][0];
209 	            invNdiag[i] += vect[j - i] * vect[j - i];
210 	        }
211 	    }
212
213 	        /*--------------------------------------*/
214 	    G_free_matrix(T);
215 	    G_free_vector(vect);
216
217 	    return;
218 	}
