[GRASS-dev] r.horizon -> G_set_window (maybe) error in southern hemisphere
Yann Chemin yann.chemin at gmail.com
Mon Jun 22 03:13:06 EDT 2009
2009/6/22 Hamish <hamish_b at yahoo.com>:
> Yann Chemin wrote:
>> Made a map in Australia, and wanted to use r.horizon on it.
>> Nothing special, a srtm map and default conditions.
>> This is the output:
>> (Sat Jun 20 16:51:57 2009)
>> r.horizon elevin=dem25m at PERMANENT horizonstep=30 bufferzone=200
>>   maxdistance=2000 horizon=horangle
>> G_set_window(): Illegal latitude for North
>> (Sat Jun 20 16:51:57 2009) Command finished (0 sec)
> I can recreate this from a single Lat/Lon srtm file. Works fine if you
> reproject it into a planimetric map projection. --->
> from the man page:
> "At the moment the elevation and maximum distance must be measured in meters, even if you use geographical coordinates (longitude/latitude). If your projection is based on distance (easting and northing), these too must be in meters. The buffer parameters must be in the same units as the raster coordinates."
> i.e. for a lat/lon location bufferzone=200 makes the buffer 200 degrees
> in all directions, not 200m.
OK, I'll try modifying this.
> otherwise, man page indicates it should work ok with lat/lon.
>> rows:       52968
>> cols:       39853
>> cells:      2110933704
> I hope you have a fast computer!
... Sigh! Definitely not, but it will have to do, as usual.
> aside- perhaps the code should use G_distance() instead of its own
> semi-baked distance() function??
Would be good for homogeneity of the code.
> Hamish
Thanks a lot Hamish.
Yann Chemin
Mobile: +33 (06) 10 11 39 26
Home: +33 (02) 35 27 08 20,
Address: Gite de Mortagne,
16 rue de la chenaie,
76110 Bec de Mortagne,
France
Perso: http://www.freewebs.com/ychemin
YiKingDo: http://yikingdo.unblog.fr/
