[GRASS-dev] Re: [GRASS GIS] #111: r.los fails in WinGRASS with high values for max_dis parameter
GRASS GIS trac at osgeo.org
Sun Mar 1 07:27:03 EST 2009
  Reporter:  gsancho       |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  major         |   Milestone:  6.4.0
 Component:  Raster        |     Version:  svn-develbranch6
Resolution:                |    Keywords:  wingrass r.los
  Platform:  MSWindows XP  |         Cpu:  x86-32
Comment (by hamish):
 OK. I have replicated the memory allocation changes from r.cva.
 It seems to run without bad allocs now. I cannot confirm that
 it no longer crashes on Windows. Someone with a Windows GRASS
 setup will need to do that.
 The patch also contains a fix done by Mark Lake years ago that
 never made it back into r.los. It fixes a problem with calculating
 cell neighbourhoods in combination with raster masks (see. pts_elim.c).
 Ben
 applied to devbr6 in r36160.
 in quick testing it looks like the MASK problem remains unfixed.
 (man page example)
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/111#comment:10>
