[GRASS-dev] Compile errors - dllmain and fmode - releasebranch_6_4 and develbranch_6
Mon Mar 2 21:58:30 EST 2009
Colin Nielsen wrote:
> Lots of compile errors on make on my vista machine (using mingw/msys
> not osgeo4w). This is the first one, from lib/datetime:
> gcc -shared -o /usr/local/src/grass-6.4_release/dist.i686-pc-mingw32/lib/libgrass_datetime.6.4.0svn.dll
> -L/usr/local/src/grass-6.4_release/dist.i686-pc-mingw32/lib
> -Wl,--export-dynamic,--enable-runtime-pseudo-reloc  -L/usr/local/lib
> -L/usr/local/pgsql/lib   OBJ.i686-pc-mingw32/between.o
> OBJ.i686-pc-mingw32/copy.o OBJ.i686-pc-mingw32/same.o
> OBJ.i686-pc-mingw32/diff.o OBJ.i686-pc-mingw32/error.o
> OBJ.i686-pc-mingw32/format.o OBJ.i686-pc-mingw32/incr1.o
> OBJ.i686-pc-mingw32/incr2.o OBJ.i686-pc-mingw32/incr3.o
> OBJ.i686-pc-mingw32/local.o OBJ.i686-pc-mingw32/misc.o
> OBJ.i686-pc-mingw32/change.o OBJ.i686-pc-mingw32/scan.o
> OBJ.i686-pc-mingw32/sign.o OBJ.i686-pc-mingw32/type.o
> OBJ.i686-pc-mingw32/tz1.o OBJ.i686-pc-mingw32/tz2.o
> OBJ.i686-pc-mingw32/values.o
> ../../lib/gis/OBJ.i686-pc-mingw32/dllmain.o && \
>         (cd /usr/local/src/grass-6.4_release/dist.i686-pc-mingw32/lib;
> ln -f -s libgrass_datetime.6.4.0svn.dll
> /usr/local/src/grass-6.4_release/dist.i686-pc-mingw32/lib/libgrass_datetime.dll)
> gcc.exe: ../../lib/gis/OBJ.i686-pc-mingw32/dllmain.o: No such file or directory
> make: *** [/usr/local/src/grass-6.4_release/dist.i686-pc-mingw32/lib/libgrass_datetime.6.4.0svn.dll]
> Error 1
> and from lib/gis:
> make: *** No rule to make target
> `../../lib/gis/OBJ.i686-pc-mingw32/dllmain.o', needed by `default'.
> Stop.
> The errors seem to be related to the dllmain and fmode problems from
> ticket #469 <http://trac.osgeo.org/grass/ticket/469>, but they seem to
> affect only the versions post-fix. While releasebranch_6_4 and
> develbranch_6 have make errors, releasebranch_6_3 doesn't have these
> errors.
It appears that someone committed only half of the fix with r35770.
[Probably because a complete fix doesn't exist; the change implies
that dllmain.c would be part of lib/gis, but lib/datetime is built
first.]
The easiest solution is likely to be to simply revert the change with:
	svn merge -c -35770 .
Unless someone can come up with a real fix, I'll revert r35770 in SVN.
